front axle
Frank van Voorst
front axle
Post by Frank van Voorst »
My front axle is slightly bent. The advantage is that my minor will always direct me to the nearest pub on the right hand side of the road. However, I rather like to have it straight. Does anyone know a place where this can be done (possibly in NL Halbe?)? Or alternatively does anyone have a better one for sale?
Frank
Re: front axle
Hallo Frank,
Give the MG Workshop a call , they might know someone
0174212608
Frank van Voorst
Re: front axle
I went to MG workshop with my diff and gearbox already, Thijs has also seen the front axle. I like to know if people have solved the same problem before... :D
Re: front axle
I found the front axle on the Bed-Pan to be bent and it was straightened by a commercial vehicle chassis repair shop in Grand Rapids, Michigan. Perhaps a bit too far to send yours, but you may find a similar establishment near to you.
If you don't have the Morris Motors service sheet that covers front axle straightening, I can send you a copy - you will need it for the dimensions.
Re: front axle
Here you go:
