Toby, is it possible that extreme play in your steering is causing your vibration problems? Some sort of wheel shimmy? It might not be the brakes at all - but happens when you hit thew brakes? If you have so much play in the steering, I'm surprised the car is driveable even without the vibration. I'd remove all four track rod ends, strip them down and see what you find. Make sure the internal springs aren't totally solid with old, hardened grease. Make sure they are assembled in the correct order - spring, sliding cup, ball, adjuster cup. Make sure the small grease hole in the sliding cup is clear. And check the balls and barrels for wear while they are off the car. While the drag link is off, you can check for any play in your steering box drop arm. Also may be worth checking that the steering drop arms at the wheels are up tight against the stub axles. It's not too big a job. Good luck!Toby wrote:Mine appears to have a split pin. When you grasp the wheel and move it the ball appears to move about 1/4"+ before it moves the rod!
