Hi
Anyone got a spare brake pedal ?? Fairly urgent , but not yet desperate !!
Brake Pedal
Re: Brake Pedal
Tony,
I think I have, I'll check, probably got a clutch one as well.
Re: Brake Pedal
It's marginally better than putting your feet through the floor and onto the road to try to stop from the excessive speeds that we travel !
Tony
Tony
Re: Brake Pedal
Tony,
I have a brake pedal but it is from a late Minor with hydraulic brakes so probably not what you are after. I have a matching clutch pedal as well. Neither are in great condition must have been outside for quite a while.
Re: Brake Pedal
OK lets rephrase that, what model do you require a brake pedal for and is it universal (except hydraulic type). Do you need it before rally?
Re: Brake Pedal
Right ! I thought you were joking , saying "why do I need a brake pedal !"
It's for a '30 / ' 31 Minor , pre hydraulic brakes. I am pretty sure that brake pedals for both OHC and SV were the same.
I do not need it before the Rally , and can collect at the Rally. I have already been offered one , but I do need two if you also have another one.
