engine spares wanted
g4pyd
Post by g4pyd »
Hi can anyone suggest a supplier of spare parts for my sv engine, rings,pistons, gaskets .
colin
Tony Gamble
Re: engine spares wanted
Post by Tony Gamble »
Colin
Try Philip Daintree at Manchester. Tel 0161 766 4487
He does a lot of rings and gaskets , and if not pistons then he will help point you in the right direction.
I have his address too if its needed.
May have plus 30 pistons, also try Eddie at Wyvern auto supplies, I believe Philip Daintree has retired, Cox and Turner engineering did my engine and got hold of valves, gaskets and rings etc.
Mike Dowley at Sports and Vintage is good for all the clutch bits, and does have pistons and valves - the OHC valves can be cut down for SV engines. Mike would also be good for big and little end bolts, sump gaskets, and other odds and sods. 01939/210458 - mention the VMR as he sponsors our summer rallies!
g4pyd
Post by g4pyd »
thank you, will give them all a ring :D
Col
