Front road springs
Front road springs
Does anyone have a spare pair of front road springs? We have a potential new member in need.
Thanks in advance.
Re: Front road springs
I am doing some research on Minor front springs as I believe that they are not identical to M type. Do you you have a full specificaton for them. I need a set for one of my Minors.
Simon,
That's right. Rear springs are identical to M, but not the front springs which are flatter on the M. New rears can be obtained from Mike Dowley. The question of specs. has come up before. The M spring specs are in Blower, but I have never seen specs. for Minor front springs.
Tony Gamble
Post by Tony Gamble »
I have a pair of supposedly "new" front Minor springs which I bought from a recent auction.
Although they are not for sale I could measure them up and see what the overall dimensions are ?
Tony,
That would be a big help. We could then use the M spring rates and your dimensions to create a complete specification.
Is it also possible to put the specification on the site ?
I would also like to check my springs.
1936morriseight
Post by 1936morriseight »
Simon,
You probably know this already, but an old commercial spares catalogue lists all minor springs, (bar 1929 - 31 fronts) as being 1·25" wide x 5 leaves + 2 rebound leaves. It suggests that 1932 - 34 fronts are all the same spec and part nos; 1930 - 31 rears are same spec & part nos; 1932 - 33 rears are same spec & part nos; 1934 rears spec & part nos. are not shared by any other years. Strangely it lists 1929 - 31 front springs but not 1929 rears - fronts are 1·25" wide x 4 leaves + 2 rebounds.
Jeff
1936morriseight
Here's the Blower reference for M springs, giving dimensions, unloaded curvatures and spring rates. I'd be interested if anyone has ever seen info. like this for Minor springs.
Tony,
When you do your measurements can you please measure the thickness of each leaf. There could be a problem having new springs made as I have been told that 3/16 inch spring steel is not available.
I have found out from some other Bullnose Morris literature what the load to make the front springs flat should be but not the unloaded curvature is. I will have to dig out my strength of materials notes !!!!
As you seem to have an original (unmolested) car could you please measure up one of your front springs including the thickness of each leaf. Also what spark plugs have you got fitted and what is the length of the thread (reach).
It is easy to identify original Morris road springs from later replacement ones. The Morris spring leaves had oval ends, while the leaves of replacement springs had squared of ends.
Morris/MG folklore has it that the only difference between Morris and MG front springs was that the latter were flattened slightly to lower the car, which is why MG front springs don't have rubber buffers fitted, because they would be too close to the chassis rail. However, the loaded main spring length must be the same on both (which means that the actual length must be different) because the shackle angle has to be the same.
Hello Ian,
Could you post a picture to show me the differences between the two springs?
Simon,
I'll take the measurements tonight .
My car had the KLG Corundite M50 plugs fitted ,they have a 1/2 inch reach
Tony Gamble
Here are pictures of my "new" Minor springs. I will measure them up this evening.
Shucks! I must remember to reduce their file size !!!
Put them in soon.
Tony Gamble
Try again !
Tony Gamble
Mmmmm ! How about these !!
