Haydon Edwards, having sold his Minor, has the following surplus to requirements. he can be contacted at haydon.s.edwards@gmail.com.
He is open to individual offers or a job lot offer.
1 block to suit large dynamo
1 front housing to suit large dynamo
1 DDS5 6v dynamo
1 block to suit large small dynamo Has liners fitted
1 front housing to suit small dynamo
1 small dynamo DEL7 or 9 that has been rewound to 12v
3 dynamo drives (UJ fork)
2 Dynamo Coupling Discs
2 new waterway plates and gaskets (Ex S&V)
3 used waterway plates
2 sumps
1 front cover/thrust/engine mounting early model
1 front cover/thrust/engine mounting later model
2 crankshaft pulleys
Morris Motors Ltd oil filler cap
1 cylinder head with new sleeve in NS rear head stud hole
1 cylinder head with new sleeve in NS rear head stud hole and 8 new valve guides (Ex S&V)
Cylinder head studs
Valve springs
1 Cylinder head to radiator outlet pipe (Cast) early model
1 Cylinder head to radiator outlet pipe (Cast) later model has position for mounting the cooling fan assemble
1 exhaust/carb manifold
3 oil pumps (I for spares only, body is fractured)
2 Oil filters
1 Oil filter bracket
Unused head gasket (old style)
4 rockerbox cover supports
Assorted oil pipes
2 crankshafts
Pinion drive (Oil pump/distributor)
Assorted shims
Box of camshaft bits (2 camshafts seen better days, housings, white metal bearings, gears, followers etc)
Complete Flywheel, clutch and cover
Flywheel bell housing
Cylinder head pressure testing kit
Cylinder head stud hole pressure testing kit
1 New firewall bulkhead ready for drilling and shaping (galvanised steel ply galvanised steel sandwich)
OHC engine parts - long list
Re: OHC engine parts - long list
All sold as a job lot.
