Dynamo OHC 12 Volt
PeterWHills
Dynamo OHC 12 Volt
Post by PeterWHills »
I am restoring an MG J2. The Engine Block is an 'M' Type. I understand I can replace a 6Volt dynamo with 12volt field coils. The casing of my Local 12v has been severely ground paper thin at one end and a braze repair is on the top casing. A REMAX dynamo would be more desirable but Lucas will do.
Re: Dynamo OHC 12 Volt
Peter,
I'll also put an ad in the Newsletter for you.
