Speedometer Gear Box B=Drive Assembly 1929 Minor
- Contact:
I urgently require the complete assembly of the speedo drive gear from the gearbox for a 1929 Morris Minor with three speed gearbox. I suspect the three and 4 speed are probably the same. If the assembly is in working condition that would be great. Kindly respond at your earliest convenience to hills.peterw@gmail.com. See attached photo of the damaged part.
- 20180609 DS9936 Speedo Drive & Driven Gears Damaged PH3_6966.JPG (579.04 KiB) Viewed 4463 times
- Contact:
Re: Speedometer Gear Box B=Drive Assembly 1929 Minor
The matter is now closed as I purchased new from Sports & Vintage, all sorted now.
Good to know Mike has these Peter.
