Clutch thrust bearings
Peter Hills is currently wintering in South Africa and reports. “I have found a local supply of sealed thrust bearings for the Morris clutch. As it is sealed, it will not require the old type steel housing but is 2mm thicker than the original bearing with the cover fitted. This can easily be accommodated by clutch adjustment so as to preserve the original clutch pedal movement. The sealed bearing rightly has the inner race protruding at the thrust holder side so rotation is not impeded. As we have plenty of weight allowance on return to UK mid February 2016 I can bring some back with me if anyone is interested. My UK landed cost will be £45.00.”
If you would like one of threes bearings, contact Peter at hills.peterw@gmail.com.
