Post
by Ian Grace » Tue Sep 01, 2015 4:43 pm
More info from Herbert:
PRE-WAR MORRIS MINOR OPEN TWO-SEATER FOR SALE IN GERMANY (Frankfurt/M area)
GY 3513 SV19059
Description: unfinished restoration project
Chassis: sand blasted, prime coated, painted black , sound, rust free
Front axle: re-painted (black), new king pins fitted
Brakes: 1933/34 hydraulic brakes fitted, anything in good order
Rear Axle: re-painted (black), in good working order, no noises
new brake pipes (copper) fitted, good wheel cylinders and master brake cylinder
new fabric discs fitted
leaf springs in serviceable condition
steering box in good condition
Wheels: 5 Magna wheels with hub caps, tires too old for road use
Petrol Tank: re-painted (black), rust free
Radiator: radiator shell in good chrome, some signs of age, radiator cap
no mascot (stolen by idiot)
modern core fitted
due to long time standstill
Engine: never run after professional re-build years ago, might need some attention
Distributor: Lucas DJ4-4, in good working order
Carburettor: in serviceable condition
Dynamo: may need some little attention, not tested yet
Exhaust: completely new, original shape, painted with enamel lacquer
Gearbox & Clutch: original 3-speed box, in good serviceable condition
Electrical Equipment: all items available, either in running order or new parts
Petrol Pump: SU-6V item with brass body, new petrol pipes (copper) fitted
Body: all body panels either repaired. welded or new constructed, all items rust free
Seats: complete new and covered with Connolly hide
also clutch
no wiring loom available!
headlamps re-painted, no glasses available
side lamps work as flash lights (amber glasses)
dashboard-gauges in running order
battery container is new
wooden framework repaired by experts with 75-yo ash wood (expensive!)
old door panel as pattern
new made instrument panel Mahogany veneer
Chrome: all chromed items either in very good condition or re-chromed
Hood: can be used as a pattern, hood frame re-painted
GY 3513 original number-plate available
plug-in windows are re-manufactured
running boards and floor boards available
After 39 years of ownership I am now seeking for a good home for that little piece of vintage
engineering due to health problems.
Please note: Due to several changes of residence all car document got lost except a bad copy
of the registration book (ending 1976 when I bought the car) and a handwritten sales
contract also from 1976.
