Mine is missing from the McEvoy. I have the complete throttle cross-shaft assembly and throttle pedal clamp that fits in the end of the pedal lever casting. I'm just mising the actual pedal.
Also, does anyone have any new pulley-type kingpins?
I'm also looking for a standard Minor near-side front wing support bracket. Mine got badly mangled somehow during shipping of the car from the UK.
If it is just the pedal that is missing how about using a large valve from a commercial vehicle with the correct size shaft(latteral thinking)
I think I may have a wing stay from the OHC Minor that was fished out of the Wey & Arun Canal. I will have a look and if I have one it can go in the Auction in the 2013 PreWar Prescott !!
So if they have the cotter slot the same side as the pulley pin offset, I'd like them!
(While I'm on this topic, there is a small clarification to the kingpin article in M142 that I'm putting in M 143 Technical Topics. The article mentions that if the wrong pins are used on the OHC Minor, then the shackled pulley fouls the axle beam. Of course it is not the axle beam the pulley wheel fouls - it is the drop arm.)
