Wanted an M type brake lever
garagiste
Post by garagiste »
Please does anyone have an M type lever I could buy or swap for another item(s)?
The Minor one is very hard to reach on an M ! Not good for my neck!!
Thanks.
Re: Wanted an M type brake lever
Wasn't the M handbrake lever the same as the Minor, but bent into a z-shape? Would it be possible to bend a standard OHC Minor handbrake lever using heat?
garagiste
Post by garagiste »
Thank you Ian.
The local blacksmith has made an excellent job of bending a standard minor lever to the required shape.
All it takes is a twisted mind. :o
