Page 6 of 19
Re: JF 4238 1933 Minor Saloon
Posted: Sat Jan 22, 2011 11:50 am
by Jpallis001
Posted: Sat Jan 22, 2011 7:29 pm
by Trevor Wilkinson
No,the concave side faces forward towards the front pulley.
Posted: Sat Jan 22, 2011 8:04 pm
by Jpallis001
Thanks Trevor - somewhere I have seen a data sheet that tells me the distance from the gudgeon pin to the top of the piston, anyone know where that info is? Is there a right and wrong way to assemble the con-rods? {look to be symetrical} - anything else not to forget when assembling the engine?
Posted: Wed Jan 26, 2011 3:20 pm
by Jpallis001
Posted: Tue Feb 15, 2011 8:57 pm
by Jpallis001
Still working on too many fronts! - Just got the engine back again, a long story for another post. - All wheel bearings replaced; Brake shoes relined/refitted; brake cams re-bushed; 3 drums on - one bake-plate to remove/straighten; starter motor in bits - making new field post; dynamo in bits fitting new bearing+bushes - rebuilding terminal/resistor box; battery box made + fitted; battery cables made + ready; carb rebuilt (not confident about needle/damper combination; wheels ready to be fitted; brake cables ready to be fitted after brake shaft sorted + front pulley carrier made ..............>>>
Going to have a blitz on the Drivers door tomorrow (welding + start new frame) + hope to finish upholstering the seats on Thursday. Stripped down the front window frame (water ingress into the laminate {looks home done!} has spoilt the screen) Just sent off samples of the screen rubbers to Ian Harris to see if he has any - anyone able to identify these sections? do they look right?
- window rubbers.jpg (83.41 KiB) Viewed 3565 times
Posted: Wed Feb 16, 2011 8:48 pm
by Jpallis001
Thanks Ian - I have two headlamps. One has a holder for a single filament bulb, no sidelight hole in the relector and has a dippling solenoid. The other has a holder for a twin filament bulb and a hole for a side lamp {no bulb holder}.
Both glasses are just that, sheets of cut glass, not lenses? So I will need to find a reflector with sidelamp hole and two lenses.
- headlights.jpg (57.47 KiB) Viewed 3530 times
also any advice on paint to use on the dashboard - have you come across any 'crackled'/'speckled' matt black paint?
Posted: Wed Feb 16, 2011 9:51 pm
Hi John,
You should be able to get mottled glass from any reputable glass supplier - the sort use in bathroom windows! They should be able to cut a couple of circles for you. The original SV headlamp glasses were cast/fluted, but the OHC cars' headlamps had a mottled/spattered texture, which is quite close to the bathroom window stuff. As for crackle finish paint, you can also pick this up in aerosols. You spray it on and wait - it crackles as it dries.
Posted: Thu Feb 17, 2011 8:48 pm
by Jpallis001
Sisters are really useful! - today we managed to complete the last seat cover. Just need to tension them + fix to frames. Will start on the door cards next. Can anyone point me towards a photo that shows what a 1933 door card + rear arm rest should look like? can anyone recommend any sheet material that works well as the base for the door cards?
- Seats1.jpg (91.2 KiB) Viewed 3495 times
Posted: Fri Feb 18, 2011 10:30 pm
the glass for headlamps is called "stippolyte", you could even have it toughened if you wanted. By the way, could only find one door glass and no others, the doors a bit of a mess but glass looks ok.
Posted: Mon Feb 21, 2011 10:29 pm
by peterb
Original rear seat detail (2008 Morris Register Rally)
Posted: Tue Feb 22, 2011 11:25 am
by peterb
!933 interiors
Posted: Tue Feb 22, 2011 11:32 am
by Jpallis001
Thanks Peter - they are the ones I need. Will have to find a piece on maghogony now. Do you have a good photo of a basic 1933 Saloon dashboard?
John
Posted: Tue Feb 22, 2011 9:39 pm
by peterb
Old wardrobes etc....good source of mahogany!
A couple of 1933/34 dashboards.
Posted: Tue Feb 22, 2011 9:54 pm
by Jpallis001
Thanks again Peter - I have cut+thicknessed some mahogany this afternoon - I will follow the dash with gloveboxes design next weekend
John
Posted: Wed Mar 02, 2011 8:19 pm
by Jpallis001
The Sun shone so I let it have a look outside while I removed the paint and discovered a few more bits in need of repair.
- bare shell.jpg (102.29 KiB) Viewed 3335 times
It looks the roof structure has been removed/modified at some stage. Anyone able to suggest what might have been done? How big is the opening roof on a Minor? Might the Vynl roof have replaced a sliding roof?
- roof from inside.jpg (79.63 KiB) Viewed 3331 times
