Page 18 of 19
Re: JF 4238 1933 Minor Saloon
Posted: Fri Dec 30, 2011 2:17 pm
by Jpallis001
Pleased to report that JF4238, or whatever it becomes, passed its MOT today. It was quite cosy driving around with the MOT Tester (my size plus a bit) and myself while he was clutching the brake meter. Thought it rude to ask if the meter registered anything, but he appeared happy. Will visit the local DVLA Taxation Office on Tueday and see what registration number they have for me.
Re: JF 4238 1933 Minor Saloon --> 806 YUJ
Posted: Wed Jan 11, 2012 1:24 pm
by Jpallis001
JF 4238 becomes
806 YUJ. Not a very interesting registration number, wonder if I can find a Mr Yuj who is small enough to fit in a Minor? I am only 6' 1" tall but, even with the seat as far back as I can get it, I find it quite difficult to fit in the car. I suppose a clever chap might have tried to sit in a Minor before he bought one!
Just had a 30 mile ride around. They are certainly interesting/different things to drive! Brakes are getting better the more that I run it. The oil pressure when cold goes off the scale; when the temperature is normal, it maintains the 1 psi per 'mile per hour' bit (in top gear); when I have climbed a few hills and the temperature goes to the 'hot side' of normal, I only get 20 psi at 35mph. I am currently using Halfords Classic 20/50 and the bearings have all been re-metalled.
- viaduct.jpg (134.4 KiB) Viewed 7814 times
Posted: Wed Jan 11, 2012 4:50 pm
Congratulations John - another one returned to the road and looking lovely. Great shot. Now with the spring just around the corner, you will be able to reap some enjoyment from all your blood, sweat and tears.
Posted: Wed Jan 11, 2012 5:43 pm
Seconded. Another one ready for the road and indeed looking fit for the next 80 years
Congratulations, many happy miles
Regards. Halbe
Posted: Sat Jan 14, 2012 2:50 pm
by Jpallis001
Thanks Ian, Halbe and all - decided to investigate low oil pressure. I dropped the oil pump from the car and took it, and my spare one to the Engineers to see if they could re-surface the plate on the best one. Not sure how they will remove the pin from the plate? While that was in progressI decided that I would pop the timing chain cover off and make sure that nothing was rattling in there. I thought that would be a five minute job! - but the crankshaft pulley fouls the front cross-member when I attempt to withdraw it. Has anyone any tricks/techniques? - Is there enough free movemnet if I drop the exhaust + jack the front of the engine?
- Crankshaft Pulley Removal.jpg (101.15 KiB) Viewed 7759 times
Posted: Sat Jan 14, 2012 5:09 pm
by Trevor Wilkinson
From memory it is almost impossible as the cover has to come a long way forward to clear the studs. The amount the engine needed to be raised was very difficult to achieve, ( I think it involved more force than I was comfortable with, but having got so far-------- you know how it is)
I wouldn't try it again.
Posted: Sat Jan 14, 2012 7:10 pm
by Jpallis001
Thanks Trevour, I will sleep on it and flip a coin in the morning - either take the engine out or just put the Oil Pump back on and not investigate my clatter. Taking the engine out with all the bulkhead etc in place looks quite awkward with those wide engine mountings. I did wonder whether it would work removing prop shaft and lifting engine/gearbox off mountings + push everything towards the back axel for a couple of inches. I then remembered how difficult it was to fit the fabric couplings. Suppose I could try to find a prop shaft with Universal Couplings at the same time?
There quite a few strange/impractical design features on these engines!
Posted: Fri Feb 03, 2012 9:22 pm
by Jpallis001
I set off to lift the engine out. I found that with the floorboards out of the way and all mountings released the front of the engine could be lifted high enough to make it worth trying to remove the timing chain cover without removing the engine. I did have a bit of luck. The large, long stud removed itself when I attempted to remove the nut. That gave me sufficient freedom to jiggle the cover free of the long studs. If this had not happened I would not have been able to remove the timing chain cover without taking the engine out. The new chain has reduced the rattle a little (why did I not replace the chain when I rebuilt the engine - a story for another day!)
I also had the oil pump plate re-faced and re-made the feed pipe. (the pin on the plate pulls out) I ended up with better oil pressure, 100+ when cold, down to 25psi at 30mph in top gear when hot after a few hills. The engine pulls quite well, starts well etc, but still has a bit of clatter/knock. I have decided to take it out and have a good look at everything before I damage anything.
I was going to upload a couple of photos but ..
Sorry, the board attachment quota has been reached.
Posted: Fri Feb 03, 2012 11:58 pm
Sorry to hear about the forukm image quota being reached. I ftp my images to the website and then paste the URL into my posts, which probably isn't much bettter, as it all adds to the size of the website. (However, with the new host, we'll have unlimited space in ther next couple of weeks.) You can also do this with Photobucket, etc. and tghen there is no limit - until Photobucket can't take any more!
If anyone has problems posting pics to the forum, just send them to me and I can upload them for you.
Posted: Fri Mar 29, 2013 4:32 pm
by Jpallis001
Not quite summer yet!
- Drift2.jpg (89.3 KiB) Viewed 7632 times
Posted: Fri Mar 29, 2013 5:02 pm
by Trevor Wilkinson
Not that bad down south!
Posted: Thu Oct 24, 2013 10:13 am
by Jpallis001
Posted: Thu Oct 24, 2013 1:50 pm
John,
Congrats on the sale - hopefully the new owner will join the Register.
I'd be very interested in the brake backplates and front springs for the McEvoy!
Posted: Fri Oct 25, 2013 10:18 am
by gubben
And I am very interested in brake parts such as bushings, cams, bolts (opposite cam), springs (for brake shoes), brake shoes.
A wiper equipment, shock absorbers and the switch (for flashers I suppose) are also on my shopping list.
/Thomas
Posted: Fri Oct 25, 2013 5:04 pm
Yes, I'm sure that John will do the right thing and distribute the parts to members in need.
