Not quite in the same league as Lee's mystery bolts, but can anyone tell me what the stud on the o/s/r of my block is for. Incidentally I presume that the numbers 4-2-31 on the block will be the casting date.
S.V. block
S.V. block
- minor 1 047.jpg (190.44 KiB) Viewed 2650 times
Re: S.V. block
This is the early type block that had a brass tap in this position for draining the coolant from here as well as the radiator tap.
