I guess the question I have is whether to revert it to its 1962 spec. with 948 c.c. engine, early gearbox and front drums. It seems to me that the mods. are all good ones, and the original parts have been saved and will definitely stay with the car. It should certainly be more enjoyable to drive with the 1275 c.c. engine, and the front disks are an obvious safety improvement (although I think I will be removing the ugly roll bar
![Confused :?](./images/smilies/icon_confused.gif)
). This got me thinking about our Minors - things like the brake mods (Bowden or hydraulics) in particular. The McEvoy has been converted to hydraulics and, as it is supposed to be good for 70 mph, does it make any sense to revert it to cables and pulleys? In this case, I don't have the original cable system (although I did collect a set of new pulleys, etc. from Ian Harris at Prescott). The decision is more difficult as the McEvoy is considerably more rare and historic than the Sprite. On the other hand, who around Seattle (apart from the Bormans
![Very Happy :D](./images/smilies/icon_biggrin.gif)
) is going to look at the Mc Evoy brakes and tell me they aren't correct. Americans don't have anoraks
. I guess there is no 'right' answer - it's down to the owner - which I guess is the way it should be. Clearly, whatever we do, we should keep the original parts if we have them, and it's probably better to employ improved parts from later Minors than parts from other makes/models entirely. After all, William Morris upgraded the Minor each season in order to make a better Minor.
But wait, what about the radiator. Most would agree that the '32 SV radiator shell is easier on the eye than the '33. Both are perfectly interchangeable (with the front valence). I have one of each, so which will I fit? I don't think I have made the final decision yet.
Then there are mods. like skimming the head to improve performance - irreversible unless the head is replaced, but at least carried out in period by MG who upped the compression ration on the M to good effect, and an y mod that improves performance has to make our cars more practical and driveable in modern road conditions. There's noting worse than plugging up a hill in a Minor in first with a queue of impatient moderns behind and trying, riskily, to pass.
Then there are mods. like fitting a VW distributor to get around a scarcity of original ignition parts and doing away with manual advance/retard.
As I mentioned, my first Morris was a 1937 Morris 8 - it had been upgraded with a Wolseley Ten OHV engine (I think the same engine as in the MG TA? XPAG?), and it went like a scalded cat - you could spin the wheels in first and second off the lights. I bet this mod would definitely be frowned upon today, but it did make for a fun student hack and the extra grunt came in very useful climbing Bathwick Hill from Bath city centre up to the University on Claverton Down with five passengers onboard.
Enough rambling - time to get a couple of wheels off the McEvoy so I can get new inner tubes fitted. I need to get this and the fabric saloon mobile so I can move them around easier and I really want to start working seriously on servicing the fabric saloon and firing her up for the first time since 1974.
Has anyone else got any interesting mods. and gone through the same sort of thought processes? a 3/4.5 Bentley perhaps?
