Thomas,
I didn't grind down my bolt heads, but I did cut a section out of the shackle webs so they cleared the bolt heads when under load and leaning back.
Keep up the good work!
SV2612 - a restoration project in Sweden
Re: SV2612 - a restoration project in Sweden
That makes sense.
Today, I hope
, I will have the time left to assemble the front axle. Ought to be a simple task...
Thomas
That makes sense.
Today, I hope
Thomas
A simple task it was...
Find the misstake!
Find the misstake!
- Find two misstakes.JPG (185.31 KiB) Viewed 8450 times
The only obvious thing I can spot is the second leaf from the top projects a shorter distance from one buckle - the side closest to the viewer- than the other. The fourth spring down projects further.
At least you put the axle on the right way round! when I did this on my M type I put the axle on the wrong way and of course the bolt holes did not line up properly with the spring.
Well, I´m ashamed - when assembly the front axle I forgot both the "rubber stop" and the caster shims.
And you are quite right - the springs differ. Something I haven't noticed myself
By the way, does anyone know where to find the two bushes that support the "brake cross shaft" (hope you understand what I´m looking for)? Outer diameter about 29 mm and inner diameter about 25 mm. If not I´m planning to buy a suitably brass tube and make them myself.
/Thomas
/Thomas
- caster shims and rubber stop.jpg (87 KiB) Viewed 8438 times
Looking good now!
Rear leaf springs assembled
Before I could assemble the rear springs I needed to replace the old bushes. I found new ones at Ian Harris, 16 mm outer diameter and 1/2 " inner. However, it was necessary to shorten them a little bit and adjust the inside dimensions slightly. When assembly the springs I noticed that there is a considerable play between the shackles and spring eye resp. chassis eye. I don´t remember if there where any washes when dismantling the springs but I think it ought to be.
After having measured the gap I found that 0,4 mm washers would do the job (two for each bolt).
Yes Thomas, there should be quite a thick washer on each shackle pin. Over the years, many of these original thick washers have been lost.
Also, the chassis was not bushed originally - someone obviously bushed yours in the past.
Good progress!
Good progress!
Steering gear play fixed
My 1931 Minor has an early worm and wheel steering box - and a excessive play as well
I could easily move the arm about 2 mm sideways!
Because my first priority is a car in mechanical good standard (rather than concours perfection) this can´t be accepted!
Adjust the bolts and locknut on the top had no effect at all.
Therefore I took off the "cover plate" and eureka - I found it. There was a visibly play between the worm an wheel teeth. By rotating the wheel to another sector the play was eliminated! Somethings are unexpected easy to fix thanks to this forum!
/Thomas
/Thomas
Great news and glad to have been able to help!
