Sump capcity
Cooperman
Sump capcity
Post by Cooperman »
I have an early M type with a tin sump. Can anyone (probably be Ian) tell how much oil it will hold?
Re: Sump capcity
Perhaps I can! According to data on the website (Site Index/Technical details), the sump capacity 4 pints and 3 fluid ounces!
Cooperman
Re: Sump capcity
Post by Cooperman »
Thanks Ian didn't want to over fill it!!! :D
Re: Sump capcity
And i'd actually recommend, slightly under-filling the sump. Modern oils are so much better than the pre-war oils and under-filling will reduce oil burning and the chance of oil ingress into the clutch.
Cooperman
Re: Sump capcity
Post by Cooperman »
If I use your figures I shall probably underfill it as I have a full flow oil filter system. Thanks anyway
Re: Sump capcity
Sounds good to me!
