6volt Batteries.
Posted: Sun Sep 26, 2010 10:43 am
by Mike Stubbings
Hi All, Does anyone know of a good heavy duty 6volt battery, Varta used to do one but I believe do not any more. I have always found Varta batteries excellent. I had a new 6v MG. Not sure about it. What batteries are you all using. Mike
Re: 6volt Batteries.
Posted: Sun Sep 26, 2010 2:15 pm
by Sam Christie
I bought a 6 volt Lincon battery in the early summer and it seems to be ideal . Their site is
http://www.lincon.co.uk/
Posted: Mon Sep 27, 2010 9:58 am
by Simon
I have had two from Lincon for different Minors. I went for the higher capacity 13 plate one, the outer case is the same size as the the original one. When using the car in the summer make sure you do not boil the battery by putting the sidelights on on long journeys to keep the charging rate down to a very low level. Also check that the winter charge rate is not much more than 10 amps (large dynamo) or 8 amps (small dynamo).
Posted: Mon Sep 27, 2010 4:10 pm
I purchased a 6 volt Lincon battery and it works very well. Sam - I have posted the parcel 4.40pm today Monday. Hightlander
Posted: Mon Sep 27, 2010 6:00 pm
by Terry Synnott
I too have found the Lincon battery to be a good buy
Posted: Tue Sep 28, 2010 10:01 am
by Simon
I made a mistake when I said 13 plate battery when it should have been the 19 plate 90 amp hr one.
Posted: Tue Sep 28, 2010 2:28 pm
Simon - I for one did not know what you were talking about anyway!!!!! Best wishes and how about a pint. Highlander.
