Page 1 of 2
Y329
Posted: Sat Jun 13, 2009 5:56 am
This just in from Ewan Lambess down under:
Just got home from a 1900 km drive to Griffith,South West NSW, to pick up the remains of a Minor. It is chassis # Y329, Engine #14567A. It has Its original motor. It has every thing I need to make another Minor. I will send you photo's soon. You may call me Mad or stupid to retrieve this but it would have gone to the scrap man otherwise. Photo's coming soon. Regards Ewan. PS: time for some sleep.
My reply:
Hello Ewan,
Great news! This car is on the chassis register - here is what I have:
"Owner - Colin McIntyre, PO Box 490, Nowra, NSW 2541, Australia. Owned 'remains' in 1984. Information from Harry Edwards via Ewan Lambess"
Now I know much more! Ian
Re: Y329
Posted: Sat Jun 13, 2009 7:45 am
This just in from Ewan, with the pic I just put on the home page:
"It was cut in half sometime in the fifties & the rear was made into a trailer by Colin McIntyre's father. Colin tells me he can remember his father towing it home but can never remember it going.It has an engine reconditioners plate riveted onto the block dating 1950. so maybe with a little luck things inside might not be to bad??"
Re: Y329
Posted: Mon Oct 20, 2014 6:23 am
by mc1925
Hi Ian, don't seem to be getting my emails thru to you, might account for lack of postings on forum ??
Ewan
Re: Y329
Posted: Mon Oct 20, 2014 2:55 pm
Apologies Ewan,
I just e-mailed John Nagle re the shock absorbers, copy to you. We'll get them on their way to you.
Cheers,
Re: Y329
Posted: Wed Nov 05, 2014 9:02 pm
Latest pics of Y329 from Ewan.
He reports: "Y329 painted, we are having a heat wave with day temps in the high 30's which meant an early start as temp in the shed was in the low 40's by midday, front guards have been painted black and ready to bolt up."
Re: Y329
Posted: Fri Dec 05, 2014 10:56 pm
A couple more images just received from Ewan. Rapid progress, Ewan!
Re: Y329
Posted: Tue Dec 09, 2014 12:01 am
by mc1925
Thanks Ian for posting the photos for me, Fitted 4 new tyres last week and have booked it in for seats and hood to be made early Jan. Have had two bumper bars made with two grooves milled into them then had the ends rolled and they are at the platers now.
Ewan
Re: Y329
Posted: Mon Dec 29, 2014 2:23 am
by mc1925
Smiths shocks arrived today, Excellent as they were only sent a week ago, seems someone was working over the christmas period.
Big thanks to Ian And john in making this happen
Happy New Year
Ewan
Re: Y329
Posted: Mon Dec 29, 2014 2:37 am
I'm shocked how fast they got to you Ewan!
Re: Y329
Posted: Wed Jan 14, 2015 8:53 pm
by mc1925
At the trimmers.
Re: Y329
Posted: Sat Mar 21, 2015 7:57 pm
Latest pics from Ewan. Looking sharp!
Re: Y329
Posted: Sun May 03, 2015 3:21 am
Posted for Ewan Lambess:
The time had come to fire up. Oil filter primed, plugs out, cranking over, no oil pressure. Off with the pump and filter (made one good pump out of four). Still no pressure. Off with the pump and sump. By squirting oil into the gallery oil was coming out the rear main as quickly as it was going in. I had some new M Type gears that I had bought from S&V many years ago. These are a lot wider than Minor gears so thought more volume might help. M Type gears need an adapter plate which had come with the kit. It would not fit over the gears, so had to grind out. Thought that was pretty average. Pump back on, now have 15 psi. Still not enough, so off with flywheel and bell housing. Rear main flogged out. Found a good bell housing and fitted a lightened flywheel that I had. Back together, pressure now 60 psi. That will have to do as I have been chasing my tail for four days. So carby flooded, ignition on, full choke, heart in mouth and she fired into life. After sitting in a paddock cut in half for 65 years, it lives again.
Re: Y329
Posted: Sun May 03, 2015 3:29 am
Ewan,
Hearty congratulations!!! Particularly after such a last minute trial!
I wish you many happy miles ahead.
Re: Y329
Posted: Sun May 17, 2015 2:32 pm
Just in from Ewan:
Took M24068 (46879H), which turned 85 this month on a club run and up turned the ex Gary Shulze car now in the ownership of Andrew Stewart of Yarrauel NSW. Andrew is also in the progress of rebuilding two other cammy Minors. Andrew plans to join the register.
Re: Y329
Posted: Sun Jul 05, 2015 2:50 pm
