Steering set up
minor178
Steering set up
Post by minor178 »
I am having a hard time setting up the steering on my 29 Minor.
No matter how much I adjust things the drag link/ pitman arm connection clash with the tie rod.
Anyone got any suggestions?
Keith Montell
Re: Steering set up
Hi Keith,
Have you got both the drag and track rods fitted above the hub drop arms? On the M Type, McEvoy, etc., because the column is more laid back, the track rod is mounted below the hub drop arms to give more s=pace, but you shouldn't need to do this with a standard Minor. Probably difficult, but any chance of a photo?
