Work on the Maddox has been slow due to a multitude of distractions. However, I figure there are 4 key tasks:
1. Get UK registration sorted - in theory, initiated with help of the Bullnose Morris Club, but ...
2. Re-fit brakes
3. Sort wiring, as what is left of original looks decidedly unreliable and I'm loathed to add even more replacement wiring in parallel
4. Fluids etc. prior to recommission/start engine.
I've decided to start with #3, removing all existing wiring, labelling ends as I go and referencing the 1934 wiring diagram to produce an Excel file of all link lengths, wire colour and function, i.e. a shopping list. My current thinking is to maintain functionality as original, so keep the frankly bonkers solenoid dipping headlights, and hoping I don't come to regret that too much.
Observations so far:
Rear lights are twin filament, presumably to support a brake light function, so additional wiring will be required there compared to standard.
Which terminal is which on the Lucas C45E Dynamo - what I would describe as 'top' is wired to +D, while the 'lower' terminal to F2. Sound right?
All wires appear to be 28/0.30, which is surely over-rated for many functions (Dip switch, horn, rear lights etc.), whereas arguably under-rated for the battery feed to Ammeter +B, feed to Accessories Fuse etc., and possibly the Dynamo connections? Though I cannot image wiring some of those latter wires with the heftier 44/0.30 cable. Thoughts?
- IMG_4387.jpeg (548.21 KiB) Viewed 2704 times
- IMG_4393.jpeg (405.78 KiB) Viewed 2704 times
