Page 3 of 3
Re: SV2612 - a restoration project in Sweden
Posted: Sat Sep 27, 2014 9:26 pm
Thomas,
I didn't grind down my bolt heads, but I did cut a section out of the shackle webs so they cleared the bolt heads when under load and leaning back.
Keep up the good work!
Posted: Sun Sep 28, 2014 6:38 am
by gubben
That makes sense.
Today, I hope
, I will have the time left to assemble the front axle. Ought to be a simple task...
Thomas
Posted: Sun Sep 28, 2014 1:44 pm
by gubben
A simple task it was...
Find the misstake!
Posted: Mon Sep 29, 2014 11:09 am
by sv4670
The only obvious thing I can spot is the second leaf from the top projects a shorter distance from one buckle - the side closest to the viewer- than the other. The fourth spring down projects further.
At least you put the axle on the right way round! when I did this on my M type I put the axle on the wrong way and of course the bolt holes did not line up properly with the spring.
Posted: Mon Sep 29, 2014 6:59 pm
by gubben
Well, I´m ashamed - when assembly the front axle I forgot both the "rubber stop" and the caster shims.
And you are quite right - the springs differ. Something I haven't noticed myself
By the way, does anyone know where to find the two bushes that support the "brake cross shaft" (hope you understand what I´m looking for)? Outer diameter about 29 mm and inner diameter about 25 mm. If not I´m planning to buy a suitably brass tube and make them myself.
/Thomas
Posted: Wed Oct 01, 2014 1:03 pm
Looking good now!
Posted: Thu Oct 09, 2014 9:27 am
by gubben
Rear leaf springs assembled
Before I could assemble the rear springs I needed to replace the old bushes. I found new ones at Ian Harris, 16 mm outer diameter and 1/2 " inner. However, it was necessary to shorten them a little bit and adjust the inside dimensions slightly.
- New bush but too long.JPG (208.05 KiB) Viewed 8417 times
When assembly the springs I noticed that there is a considerable play between the shackles and spring eye resp. chassis eye. I don´t remember if there where any washes when dismantling the springs but I think it ought to be.
After having measured the gap I found that 0,4 mm washers would do the job (two for each bolt).
- Right spring assembled.JPG (203.11 KiB) Viewed 8417 times
Posted: Thu Oct 09, 2014 12:53 pm
Yes Thomas, there should be quite a thick washer on each shackle pin. Over the years, many of these original thick washers have been lost.
Also, the chassis was not bushed originally - someone obviously bushed yours in the past.
Good progress!
Posted: Tue Nov 11, 2014 3:52 pm
by gubben
Steering gear play fixed
My 1931 Minor has an early worm and wheel steering box - and a excessive play as well
I could easily move the arm about 2 mm sideways!
Because my first priority is a car in mechanical good standard (rather than concours perfection) this can´t be accepted!
Adjust the bolts and locknut on the top had no effect at all.
Therefore I took off the "cover plate" and eureka - I found it. There was a visibly play between the worm an wheel teeth. By rotating the wheel to another sector the play was eliminated! Somethings are unexpected easy to fix thanks to this forum!
/Thomas
- Steering gear.JPG (337.82 KiB) Viewed 8401 times
Posted: Tue Nov 11, 2014 10:05 pm
Great news and glad to have been able to help!
