SV on ebay............
Re: SV on ebay............
This one was advertised back in April - for GBP 12,000. Don't expect the reserve to be met...
blimey, looks nice, interesting to see steel on the rear inner wings, this was on the 34 model, didn't realise these had this before the body change?.....
I have never seen a 31 radiator looking like that. :o :o :o What else is wrong??
I am no expert but the Rad is 1933. Wheels are early. One piece screen (Two piece in 1933) It will be interesting to see what it fetches. Sailed through the MOT to day but got a fright!!- Whilst on the ramp I was asked to take a look and noticed one nut and bolt missing from the propshaft!! The tester did not spot it. On getting home I replaced the missing nut and bolt and tightened ALL the others!!! (all loose) 2976 miles since last MOT.Highlander.
Mike Stubbings
Post by Mike Stubbings »
Should there not be a glove pocket on the left of the dash and are the door pockets correct, mine are set behind the main panel. Can someone tell me is the Minor starter motor the same as the MMM. Mike
Yes, I believe the starter (M35) is identical.
