Hi Ken,Ken Martin wrote:Incidentally I disagree with Ian’s advice to take metal off the head to improve the performance!
Your saloon certainly seems to go well on the road. Are you running an original Minor cam as well? The standard Minor was rated at 20 bhp I believe, and the M Type was 27 bhp - a considerable increase, but some of this must also have been due to the larger carb. And the M's performance on the road would also have been considerably helped by its lighter weight. (I'm amazed how heavy the Semi-sports body is - the ash frame is built like a tank by comparison to the M! More like a Quarter Sports than a Semi Sports!).
I must admit that I have always raised the comp to M Type spec on all my OHC Minors, and fitted a 12/12 cam, and the resulting performance has been good. What I have not done, I don't think, is run a 12/12 cam in an unskimmed head. Scope for some scientific research here? Minor comp/Minor cam, Minor comp/M cam, M comp/Minor cam, M comp/M cam, and the same again with an M carb/manifold!
Footnote on cams - I don't think standard Minor cams are obtainable - so it's Hobson's choice if your cam is worn - unless you go to the expense of reprifiling.
