Parts wanted for 1929 Minor tourer
OHC Minor carburetter (SV one currently fitted). Or just a bottom feed bowl.
Correct firewall mounting coil - push-in HT lead (modern Lucas unit currently fitted)
9/44 CWP (Morris 8 ratio currently fitted)
6V Sparton horn (I have a 12V for swap)
Original white-faced speedometer
Set of cast brake drums - either late OHC or SV wide rim drums (which could be machined down to suit the early backplates). The car currently has the original flimsy early pressed drums fitted.
Thanks.
