Parts for sale and wanted
1930’s Morris Minor PARTS FOR SALE.
Morris Minor Pre-War dismantled chassis frame. Including front and rear axles, springs, wheels, brake cross shaft etc., and a set of plans to build a two-seater tourer body. Also V5C 1933 two seater tourer registration document, registered “KY” and four numerals. Offers over £1,400.
Set of Con-Rods and Front Bush for 1930’s Morris Minor Sidevalve and O.H.C. engines. Re-metaled, ready for machining. £160.
Pair of Timing Sprockets for 1930’s Morris Minor. (Side Valve Engine). £20.
6V Starter for 1930’s Morris Minor. Working order. £50.
Horizontal Flange SU Carburetor for 1930’s Morris Minor. Working order. £85.
Complete set of 3 Speed gears for 1930’s Morris Minor. The gears appear to be in very good condition, apart from some slight pitting on spigot shaft splines, which would not be detrimental to operation or performance. £80.
Front Axle Beam for 1930’s Morris Minor. £40.
Calormeter. Very nice, bright condition, but requires attention to return to working order. £45.
Pair of 1933/34 Morris Minor Saloon Front Seats. Basically good, but require recovering. £75.
Steering Wheel to fit 1930’s Morris Minor or Morris 8. In nice condition. £65.
I am gradually having a clearout, and so will also have other 1930’s Morris Minor parts for sale in due course.
All surplus to requirements.
WANTED. For 1930’s Morris Minor Side Valve Engine. Spiral Gear which fits on crankshaft, that drives oil pump and distributor.
Tel: 01782/515802. Brian, Staffordshire.
Re: Parts for sale and wanted
At last, someone who needs the spiral gear for sv engines!!! Still waiting for price from engineers but apparently it's very hard to cut the spiral teeth. At least thats a batch of 2 now....
Spiral gear
Just out of interest, what is the difference between the ohc and sv spiral gears? Is it not possible to adapt the earlier ones?
