Pre flight checks all done...........
IE, i dragged MT out of the garage this eve with its customery layer of dust, turned the cut-off key, turned the fuel on, waited ten secs, retarded.... choke..... hit the button and.................... away she went...:)....... wound the idle up a bit, let her warm though... then took her down the road just to check she still goes.... and stops..ISH!!..
Mot on saturday morning, that should be interesting............!!
Re: Pre flight checks all done...........
good luck! :D
Good job Ronald! Just in time for summer!
As expected, she passed................. the only thing i noticed was that the track rod joints have maybe a bit too much play in them................ hence the wobbly steering.,...!!!
Fantastic - well done. Is the new engine fully run in yet?
Ian :D
Well. it certainly seems to go ok Ian, i should get round to changing the oil, maybe after the run...............
I'm assuming there will be room and access at prescott for trailers and tow cars to be left for the sunday..????
Tons of space all weekend at Prescott - we have the hill to ourselves for the weekend. 8)
