Crankshaft Thrust Washers
Posted: Mon May 03, 2010 6:04 pm
I am currently fitting a new crank into an OHV Morris engine and have measured the fount crankshaft thrust washer and have found the end float to be about 20tho. What does the thrush washer do as the end float of the crank is taken up by the ball bearing at the front of the crank? How do I reduce the end float on the thrush washers?
Thanks for any help
David
Thanks for any help
David
