Hi all, I have lost my clutch pressure pins this is operating pin P13 in Harrys Information manual,
all three have been misplaced or lost since i stripped the engine down and now its ready to go back in,
where can I get replacements?
or can These be made ? I know they are hardened steel any one know the size or a supplier
regards Colin
when every thing seems to be going wrong you can bet it is?aargh
clutch pressure pins 32 minor
Re: clutch pressure pins 32 minor
Colin, I got these pins direct from Sports and Vintage, Shrewsbury. 01939 210 458. They supply nearly everything for our type of clutch - Are your fingers worn? Highlander.
Hi Many thanks have just rung them and they will send them today ,
fingers are worn but I don't know by how much mabe a couple of thou
thanks again Colin
thanks again Colin
S&V can also supply the corresponding thrust buttons for the pressure plate if yours are worn. I'd also recommend you fit MG J2 springs while your clutch is in pieces - also available from S&V. They are dimensionally identical to Minor/M Type springs but have a higher spring rate, so hold the clutch together harder!
Incidentalluy, I have a pressure plate that was never drilled for thrust butons and it has three pretty good dents in it from the pins! I suspect that the buttons were a very early mod.
thanks everyone.
engine back together now and waiting to go back in chassis
Colin
Colin
