Page 7 of 8
Re: NV 2803 - 1933 McEvoy Special
Posted: Thu Jan 01, 2015 7:48 pm
OK - so it's New Year's Resolution time.
One of mine is to get on with the restoration of the McEvoy this year. The car has been here for about three years now and last year I pulled it completely to pieces, which was a necessary first step to restoration in this case.
I could start by having the chassis blasted and then start building up the rolling chassis - but that's all the easy work, and even when at a rolling, or even driving chassis stage, that's only a fraction of the total job, and the easiest fraction at that. On top of that, if I restore the chassis first and then use the frame to jig the ash frame, the chassis will need restoring again when the body is done!
So I propose the bite the bullet and start with the body, and the first part will be to build up a new floor assembly on the chassis. The floor is the worst part of the body, as most of the ply has delaminated over the decades in damp storage. I am hoping to save much of the ash superstructure. It's far too cold in the workshop to do much before the spring, but that gives me time to source the ply, ask, screws, etc. and to make plans.
So, what's in your garage awaiting attention?!
Posted: Sun Apr 12, 2015 9:06 pm
So today was the first opportunity I have had this year to get out into the garage and sort things out after the winter. I spent the day gathering together the rolling chassis parts of the car which I had stripped down to the bare chassis last summer and roughly re-assembled the rolling chassis which I will now use as a mobile bench to rebuild the body on. Only when the body is complete will I go through the chassis, so that it doesn't get ruined while the body is being sorted. This ploy also has the advantage that the project is mobile and can be easily rolled outside to work on in through the summer. Also, it gets the most difficult part of the project out of the way at the outset.
Posted: Sat Mar 04, 2017 8:58 pm
Almost two years have passed since my last post - and the last time I did any significant work on the McEvoy. My excuse is that I joined Boeing shortly after the last post and I'm extremely busy designing the Boeing 777X computer flight control system. The 777X is the latest Boeing airliner and its first flight is scheduled for late next year.
The other difficulty I have had is lack of space. My garage is crammed with cars and Moths with no space to work! However, I'm planning to build a large workshop this year which will sort that problem out.
The other major boost to the restoration came this week. I was chatting on the MMM forum and I noticed that another poster was located in the USA. It turns out that Brian Sullivan, owner of an MG PA, lives less than ten miles from VMR HQ in Washington State! How does that impact the McEvoy restoration? He has numerous local specialist contacts for seasoned ash, expert panel beating and he also runs a furniture restoration workshop so I'm taking him my original instrument board next week for restoration!
So hopefully, serious progress will be made in the coming weeks and months.
Posted: Thu Mar 16, 2017 9:03 pm
This morning I took the instrument board to Brian Sullivan for restoration. It is in excellent original condition with no extra screw holes, but the varnish has faded over the decades, as witness the un-faded area under the steering column bracket. Just a small scuff under the left side. Brian is a high end furniture restorer and here's his analysis of the board:
"The McEvoy instrument board is of Honduras Mahogany. The wood has been grain filled prior to finish. The small dents to the left side of the bottom edge can be steamed out I think. The color original is Natural Red Mahogany and most likely a varnish. We could do a high end yacht varnish as I plan for my own P-type which is probably the proper historic finish. There is so little damage to the original wood that little else other than finishing is needed."
So I gave Brian the go-ahead to restore. I'll post before and after photos here when I get it back. The instrument panel itself is going back to England for restoration shortly.
Meanwhile, I'm boxing up the radiator to go to the Vintage Car Radiator Company
http://www.vintagecarradiatorcompany.co.uk/ (now moved to the Bicester Heritage Centre) and the fold-flat windscreen is going to Wessex Workshops for restoration.
Posted: Fri Mar 17, 2017 3:39 pm
The before photo. The after photo to follow soon!
Posted: Sat Mar 18, 2017 11:31 pm
While the instrument board is away being refinished, I decided to tackle the panel itself. I was thinking about sending it off to one of the professional restorers in the UK, but I have decided to have a go myself. That way I can probably save more of the small, original parts. And I'm looking for something with a bit of patina rather than completely overhauled and new-looking instruments.
The panel is in a bit of a sad state - see below - but under all the filth and decay, it is 100% original and complete.
The only difference between a standard SV Minor panel and the McEvoy panel is that the slow running control on the right side of the panel has been replaced by a starter cable and pull knob that connects to a relay switch on the firewall. This was an original McEvoy modification. (As far as I can see, there was no slow running control on the McEvoy.)
The speedometer is definitely beyond restoration, but I do have a sound replacement. After cleaning up the front of the PLC2 ignition switch I now know that I need an MRN 27 key.
Some of the original varnished cotton wiring was still in place, but interestingly, there were a couple of lengths of plastic-covered wire. Since the car has not been on the road since 1957, I'm wondering when this wire became available.
The next step will be a few coats of primer filler to fill the corrosion pitting, and then the finish coat.
And here's the panel stripped and cleaned up:
And the reverse showing the stamped number 333 and the letter D just above the speedometer hole.
Posted: Tue Mar 28, 2017 3:59 am
Posted: Tue Mar 28, 2017 6:04 am
Meanwhile, I visited Crosscut Hardwoods in Seattle today - an incredible emporium that stocks every hardwood imaginable - including dozes I have never heard of. They also have a great supply of Russian Birch ply - perfect for the McEvoy floor
Here's their American Ash stock:
And here's their birch ply:
There's a McEvoy hidden somewhere in this little lot!
Posted: Fri Aug 04, 2017 5:09 pm
More progress. The instrument board is back from Brian Sullivan's workshop and looks super:
And I collected the McEvoy radiator script while in England. here it is as a rough casting before fettling:
Now that I have the radiator script, the next job will be to ship the radiator to England for a full rebuild. I'm also sending the windscreen over to Wessex Workshops for restoration. I'm trying to get all the 'big tickets' jobs out of the way!
I also brought back from England a set of the correct pulley kingpins and bushes from Ian Harris, together with a pair of ignition keys to match the original PLC2 ignition switch that came with the car. I am now in the process of disassembling this switch to restore it.
Now that I have the birch ply and some ash, I am hoping to make a start on the ash frame before the winter sets in.
Posted: Sun Sep 17, 2017 5:35 pm
When I got the McEvoy, it had been converted to hydraulics - '34 Minor. I've spent some time sourcing all of the parts needed to convert back and now that Peter Hills has sent me two brake SV cam levers in exchange for a pair of 1929 levers for his tourer, I have virtually everything except for the hand brake cable and footbrake rod to the cross-shaft. I have asked Ian Harris if he has these. I have also ordered from Ian Harris the four swivel pins and brass adjuster nuts. I have the brake pulleys and chassis brackets.
If anyone has a need for any hydraulic brake parts, I can supply, ex-McEvoy.
The restoration of the McEvoy has been a slow process and has not got very far in the last few years, due to pressure of work, other projects, and life in general - not to mention running the Register. However, two things are going to change all this. First, Jayne and I are planning to retire back to England in about 7 years from now, and we will be bringing back the McEvoy and the fabric saloon KR 5670. So I'm thinking that if I can get the driving chassis and ash frame all sorted here, I can get the paneling and upholstery, etc. done professionally in England, unless I can find the right specialists here. Either way, the ultimate goal is to have it back on the road and fully sorted before the Minor centenary in 2028.
Posted: Mon Jan 27, 2020 12:11 am
Harvey Pole kindly sent me a starter motor spacer ring which was one of the parts I was missing. Thanks Harvey!
Posted: Fri Apr 10, 2020 11:27 pm
More progress. I have managed to source a pair of good front road springs from Frank Ashley. So I'm getting close to having everything I need to complete the rolling chassis. But I am still in need of the rod that connects the handbrake lever to the brake cross-shaft, if anyone can help?
Posted: Fri Apr 10, 2020 11:29 pm
And here is the original Ashby steering wheel which I was going to replace with a new item, but on reflection and close study, I'm hoping to have restored. The end result might not be as shiny as a brand new one, but it will be the original wheel to the car.
Posted: Tue May 12, 2020 8:57 pm
Considerable progress in the last month. I now have the entire cable braking system to replace the hydraulics and bring the brakes back to standard. This has been a major task as there are so many components to the system. I have also found a good local blasters, so have stripped the chassis right down to the bare frame and will have it blasted and painted, along with some other large components shortly. I have also stripped the rear axle down to its bare components. The hydraulic brake assemblies were removed and also the diff. and I was relieved to find the entire diff. unit in pristine condition internally.
If anyone needs a set of four complete hydraulic backplate assemblies, let me know.
But the best news is that I have carried out a very close survey of the body. This fell in two when I removed it from the chassis as the ply floor was in a terrible state. However, it turns out that ALL of the ash frame is rock solid! Not only that but the steel paneling is also virtually perfect - apart from some rust bubbling along the lower edges of the doors. This means that the entire original body, apart from the ply floor components can be saved. Not only is this tremendous news from the originality standpoint, but it greatly reduces the amount of work necessary to recommission the car, not to mention saving a couple of years!
Meanwhile the steering wheel has been sent away for restoration and Ian Harris has shipped the next package of smaller chassis components I need to complete the rolling chassis. Finally, Frank Ashley has sent me a pair of good front springs, so I think I now have all of the parts to completely restore the rolling chassis. My goal therefore is to get to the complete rolling chassis stage this year and then re-jig the body on the frame with the new ply floor.
Posted: Thu Nov 19, 2020 9:50 pm
See two posts up for the unrestored steering wheel.
Here it is after expert restoration by Ben Cordsen. He has done a fabulous job, using all of the original components.
