Some new parts being made
I'm having a few parts made right now and can have some additional ones made if anyone is in need. They are:
Battery boxes - ready to fit, just need drilling to match the bolt holes in your chassis and painting. Made in galvanized steel. Suit all Minors and early M's, I believe.
Bonnet step plates - the triangular platforms which sit atop the chassis rails. Two types - the OHC ones which have an additional triangular fillet at the back - behind the scuttle supports, and the SV type which don't. Also the 1929 type which are slightly different at the front to accept the early radiator mounting platform. Galvanized steel
Running board to front wing brackets - suit all Minors. Galvanized steel. Drilled with slotted holes as per original - just need painting.
Sets of scuttle tank straps.
Let me know soonest so I can order appropriately. Can't quote prices yet, but they will be reasonable and not too heavy to post from here.
Spare wheel wooden mounting blocks - suit saloons, tourers and 32-34 SV 2-seaters. These will be turned and drilled but you will need to finish the curve to suite your body type. Come complete with mounting coachbuilt, but not the steel spare wheel carrier itself.
Radiator tie rods - single 1929 type and double later type. BSF threaded but no forks for the front of the later ones. These should available elsewhere.
Any use to anyone?
Any use to anyone?
Re: Some new parts being made
Hi ian put me down for a pair when you know the price?
regards colin
regards colin
I'm also in for the running board to front wing brackets.
Great,
So far on the running board brackets, we have:
Ian Grace 1 pr
Ken Martin 1 pr
Colin Johnson 1 pr
Halbe 1 pr
Any more takers?
Ian Grace 1 pr
Ken Martin 1 pr
Colin Johnson 1 pr
Halbe 1 pr
Any more takers?
in my ignorance what are scuttle tank straps?
Colin
Colin
Hi Colin,
The OHC and 1931 SV cars had fuel tanks mounted in the scuttle - on the back of the firewall. They were attached by a pair of two-piece steel straps. These are what are being made.
Certainly Sir!
Hello Ian,
Still waiting for the running board brackets................................................
Do you have a delivery date
Hi Ian have you got any battery boxes ?
regards steve
regards steve
Halbe,halbe wrote:Hello Ian,
I had some of these made by a concern in Grand Rapids - before the great trek west. Currently don't have the opportunity to make any over here on the left coast - particulalry as someone has run off with ALL my Minor spares and patterns, it seems.
Similar situation with the battery boxes I'm afraid - although I do still have the card pattern.
well Ian,
You only asked me nearly two years ago. (june 2008) never got an answer.
Hope that Ken and Colin got their brackets.
sorry to hear about your spares.
Hi I an i would be interested in the card board cut out and make a battery boxif you can supply one
regards steve
regards steve
Yeah - sorry about that Halbe (and others) - this was just before GE laid me off which started the chaos which ended with us moving to Seattle - so the spares situation got away from me.halbe wrote:well Ian,
Hello Ian,
No problem
No problem
