Page 22 of 24
Re: VG2007
Posted: Tue Nov 26, 2013 2:30 pm
first result doing the fabric on the body.
Re: VG2007
Posted: Tue Nov 26, 2013 4:47 pm
VERY nice Halbe!
Re: VG2007
Posted: Thu Nov 28, 2013 11:02 pm
Thanks Ian,
Doing the rest will take some time. It's not very hard work but there is lots of it......but the result will be fine!
ill post more pictures as more gets done.
Re: VG2007
Posted: Fri Nov 29, 2013 12:49 am
Can't wait!
Re: VG2007
Posted: Sat Nov 30, 2013 6:25 pm
today’s work.....
Re: VG2007
Posted: Sat Nov 30, 2013 7:51 pm
Getting close Halbe. Any idea when it might be ready for the road?
Do you have the original guttering? We have a member that is interested in the construction of the guttering. On my fabric saloon, it looks like it is a steel J-section covered in fabric, but it isn't obvious, without removing it, how it is constructed/covered.
Re: VG2007
Posted: Sat Nov 30, 2013 8:53 pm
My aim is summer 2015/16.... all depends on time/money
Yes i have the original guttering,Here are some pictures .It looks like a rubber profile (J like) covered in fabric, mine also needs replacing......
Re: VG2007
Posted: Sat Nov 30, 2013 9:32 pm
Thanks for the gutter images - very interesting. Will forward, and have a think about replacement options.
Re: VG2007
Posted: Sat Nov 30, 2013 9:36 pm
What about sending a slice to Kartik or Ian Harris. I will also ask around over here .
Re: VG2007
Posted: Sat Nov 30, 2013 9:59 pm
Good idea - and to Paul Beck Vintage Supplies and Woolies in the UK - the two leading vintage coach trimming suppliers. I can supply contact details if you could supply an inch of the guttering.
Re: VG2007
Posted: Mon Dec 09, 2013 10:34 pm
Progress,
Re: VG2007
Posted: Mon Dec 09, 2013 11:03 pm
Outstanding. So much restoration work doesn't show, but fabric workd certainly does highlight progress. So that rear panel is bolted in for good now? Did you use any heat to get those quarter panels smoothly covered, or did you just pull the fabric like hell? Or both?!
Re: VG2007
Posted: Tue Dec 10, 2013 2:29 pm
Bolting everthing up is the last step .......first is doing all the individual panels and making all the strips/beading? between the body and the rearwings ,rearpanel and the beading between the bonnet and the body. Then it's bolting up time.
Fitting the doors to check for even gaps ect ect ect
The "problem" i have with the fabric is not so much not enough material but where to leave the surplus......I get a little better at this everytime i have to do this.
Force is something i certainly use and heat not nearly as much..
Re: VG 2007
Posted: Thu Dec 26, 2013 9:55 pm
One step at the time.......tricky bits take longer.
Re: VG 2007
Posted: Thu Dec 26, 2013 11:16 pm
I should imagine the doors will be the trickiest part - ensuring satisfactory clearances all round.
