VMR Autumn pub meet, Sunday 24th October at the Old Bull, Inkberrow
OK, so we'll plan to meet at the Old Bull on Sunday 24th - the last Sunday before the clocks go back, so will give another hour of daylight to travel home.
All very welcome.
Call the landlord and Register member Joe Reed on 01386/792428 if you would like to book a table.
https://www.oldbullinkberrow.co.uk/
All very welcome.
Re: VMR Autumn pub meet, Sunday 24th October at the Old Bull, Inkberrow
If I can fix the issue of the core plug, see my last post in the PWP 2021 thread, then I'll certainly be there
Good luck, but if not, do come in the modern anyway.
Good news! I've just returned from a short test drive and the new plug is holding and watertight. Fingers crossed.
Well that IS good news!
Photographer Peter McFadyen is also planning to attend - he lives less than two miles from the pub.
Also a bunch of Austin 7's are planning to attend, including Roly Alcock in his 2-seater, coming from Upton.
Driver's door lock fell apart last weekend while on the way home from spectating at the VSCC Welsh Trial. I was thankfully able to continue the journey home as the door wasn't interested in swinging open, even on the bends I'm hopeful I'll be able to secure a replacement lock this week so should still be there on Sunday. Ian, can you remind me what time the meeting starts? I have it down as 11am.
Hi Jonathan,
The opening time is 11-30, so feel free to turn up any time after that.
How was the Welsh? Muddy or dry?
Thanks Ian. The conditions were far too dry they were even spoilt by the appearance of the big round yellow thing in the sky on Sunday!!!
Managed to take two short videos in the Minor, one driving along the A44 east of Kington, the second one driving through Pembridge.
www.youtube.com/watch?v=9aai9Iit1C0
www.youtube.com/watch?v=xpMlnWT55cs
Excellent videos! Going well at around 45, 60 psi, charging AND a fuel gauge that works!
Yes, not a bad combination When cold the oil pressure is up around 80-90psi and gradually drops over a 5-10 mile journey to around 60psi and stays there for the duration. At tickover it sits around 60-70psi cold and drops to as low as 20psi once properly hot, in line with the drop from 80+psi to 60psi at speed. I need to replace the incorrect ammeter (it's a 30-0-30) with a correct 20-0-20 ammeter, especially given that it's a faulty unit. I borrowed a 20A ammeter and it showed that the current generated is stable. The one that is fitted tends to bounce all over the place. I have a replacement door lock on its way to me. It will hopefully arrive tomorrow and I can fit it and get back out on the Queen's Highway in time for the weekend.
Took a bit more effort than I was expecting, but I can now say the replacement driver's door lock is fitted and working. I thought it would be a 5-10 minute job, but it ended up taking more hours than I care to think about. The issue was one that wasn't immediately obvious. With the new lock fitted the door just would not shut. It took me ages to figure out what was causing the problem. It turned out to be the pin on the new lock being slightly fatter than on the original item. The locating hole on the striker plate fitted to the B-post was too small so the pin just wouldn't fit. I ended up reducing the thickness of the pin and enlarging the hole in the striker plate. The door appears to be shutting better than ever.
Good job done! Hope the weather is good for Sunday?
Cracking little meeting, even more enjoyable than the Springtime one. The weather was the only thing that spoilt it. Here are some photos. I very nearly came away without taking any! I'd already left the car park and had to jump out and take a few quick shots before heading off
- 20211024_134902.jpg (7.09 MiB) Viewed 1810 times
- 20211024_134859.jpg (7.37 MiB) Viewed 1810 times
- 20211024_134854.jpg (6.89 MiB) Viewed 1810 times
- 20211024_134843.jpg (7.16 MiB) Viewed 1810 times
Two more images from today.
- 20211024_134919.jpg (6.56 MiB) Viewed 1809 times
- 20211024_134909.jpg (6.91 MiB) Viewed 1809 times
