OHC Minor carburetter (SV one currently fitted). Or just a bottom feed bowl.
Correct firewall mounting coil - push-in HT lead (modern Lucas unit currently fitted)
9/44 CWP (Morris 8 ratio currently fitted)
6V Sparton horn (I have a 12V for swap)
Original white-faced speedometer
Set of cast brake drums - either late OHC or SV wide rim drums (which could be machined down to suit the early backplates). The car currently has the original flimsy early pressed drums fitted.
Thanks.
Parts wanted for 1929 Minor tourer
