Wanted to Morris Minor Two Seater 1934
KramerKLS140
Post by KramerKLS140 »
For engine,4st valve collets,2st valve caps. For 4 speed gearbox, top cover, change speed lever, gear knob. Also front springs, left and right, brake pedal, fuse cover, prop shaft. Brackets to the steering-column, part nr 38155( from The Complete Morris Minor page 173,174 pos B39 my car has ch.no 40629). Bracket to ignition control and horn button and dip switch, oil suction pipe, oil cap engine, dip stick. Camshaft retainer ring 36556, retainer plate 36559, retainer ring 36560. Housing and securing ring to rear crankshaft bearing 36941 and 36545(parts no,from The Complete Morris Minor, page 139 and 140).
