Parts wanted for Morris Minor Two Seater 1934
KramerKLS140
Post by KramerKLS140 »
I need the following parts for my Morris Minor Two Seater 1934.
CW&P 8x34, dynamo with fan, carburetter SU O.M with 1” throttle diameter, distributor, oil filler cap,
radiator cap, gearbox cover and lever, Cardan propeller shaft, front lamps, front road springs complete, instrument panel with gauges,
radiator badge, brake cross shaft bracket, bracket to facia board (steering column), ignition control rod assembly, triangular scuttle supports, radiator tie rods,
three 18" wheels and wheel spokes.
Anders
Re: Parts wanted for Morris Minor Two Seater 1934
Anders is our new member in Sweden where Minor spares are thin on the ground. So he really need help with his project. Who can come to his aid with any of these items?
KramerKLS140
Thank you, Ian !
Anders
KramerKLS140
If someone has new or used spare parts, I'm grateful for you
want to hear from you, even if you can talk about someone who can have spare parts because i
would like to get my car driveable.
Hi Anders,
Have you contacted Ian Harris? He sells a very good range of new spares and sometimes has used parts. He would also probably be able to put you in touch with others who may have the used parts you are looking for.
Ian can be contacted at ianhms@outlook.com.
KramerKLS140
God Evening Ian
I have contacted Ian Harris and bought some spare parts from him and he is looking for more
spare parts for my car.
But I hope there are more people who can help with spare parts.
Even bad parts can be interesting because you have something to do
check if I have to re-manufacture.
So do not hesitate to tell you if you have any of the travel items.
Anders
