Parts wanted for 1934 Minor Maddox special
I'm looking for the following - can anyone help?
Lucas steering column-mounted 6V coil
Firewall mounting 6V SU fuel pump
1934 style steering column bracket
1934 style steering column switch stalk
Re: Parts wanted for 1934 Minor Maddox special
Updated wants list!
SV Minor standard front number plate cross-bar - the flat bar type with twists at each end so that the number plate is mounted vertically.
Also needed is a pair of front floor board angled steel brackets if anyone has any? Mine are completely absent.
Thanks.
simonh
Post by simonh »
Are these angle brackets the same as the cammy ones - part Nos .........?
Yes, I believe they are, Simon.
simonh
Post by simonh »
Misunderstood Roger Birds email about cylinder head thickness - his is 41 mm thick so similar to Ian Harris's. Was your head/ combustion chambers copper plated ?
The previous reference to cylinders 2 & 3 referred to the block as the exhaust valves are adjacent and need the heat to be transferred away as quickly as possible. The cleaner to get rid of the limescale here is Fernox DS [kettle and iron cleaner].
PS Do you want me to search for a replacement head for you.
simonh
Post by simonh »
The cleaner should have been Fernox DS3.
Ronald Hogg is having a clean out and may have the floor brackets , according to Harry Edwards manual are the same for SV & OHC.
Thanks Simon,
I'll contact Ronald.
No, my head was not plated.
simonh
Post by simonh »
Almost certainly going to Beaulieu next week end, do you want me to hunt for anything. What? and price limit.
I could do with a 6V SU fuel pump at a reasonable price. Unless anyone else can supply?
simonh
Post by simonh »
6V SU pump. Not now going to Beaulieu. May I humbly suggest that you buy a new pump from Burlen with alloy base [ £100 + VAT] or brass base [£200 +VAT] as any s/hand 6V pump, not particularly common, would need to be refurbished with at least a new diaphragm to cope with modern fuel [refurb kit £30 + VAT]. Would the price be negotiable !!
Great - good plan, thanks.
simonh
Post by simonh »
I
If you bid and win SU. If you have it sent to me at Flat 2, Old Museum Court. Museum Hill. Haslemere. GU272JR. I can check it over,
report back and refurbish if you would like.
S
Simon, the brass one is being sold by 'Fairorgan', which I suspect is Nick Williams. I have e-mailed him
simonh
Post by simonh »
The pump I was referring to was sold last night by a chap in Sandhurst village.
