Parts wanted for my McEvoy
Looking for a pair of sound front road springs, sound radiator (just the core/tanks - I have the shell), bare track rod, starter motor spacer ring, the rear cam bearing cover and two SV Minor brake cam levers. Can anyone help?
Thanks,
moonlight frolic 11
Re: Parts wanted for my McEvoy
Post by moonlight frolic 11 »
Ian, did you get the SV cam cover, I'm sure I posted that I have this?
Mike
michael.p.rose@btinternet.com
Hi Mike,
No, I am still in need of the rear cam bearing cover. is that what you have? Its the small triangular pressed steel plate, not the tappet cover.
simonh
Post by simonh »
There is an 1.25" downdraft SU on ebay from Fairorgan.
Do you still need the triangular camshaft cover ?
Thanks Simon. Yes I do need the cam bearing cover.
Most of these parts found now, but still looking for a bare track rod. Mike is corroded and bent and doesn't look too safe!
Also looking for a replacement SV cylinder head - the later one-piece type.
I have a Derrington 3-speed remote but the McEvoy box is 4-speed. Does anyone have a 4-speed remote that they are willing to swap for a 3-speed?
Has anyone had any SV Minor fuel tank straps made? Mine are definitely second-hand!
