How remove king pin
gubben
How remove king pin
Post by gubben »
How do you remove the king pins (SV)? I assume they are to be pressed out from upside …
Re: How remove king pin
The hard part is usually getting the tapered cotter pin out. Don't try to tap in out, because multiple light hits won't shift it and you will just spread the pin. I give them a good soaking with WD40 and then give them one really hard clout and that usually works.
Once the cotter pin is out, it is usually easy to drive the kingpin out of the axle eye. It should come out either way - up or down.
gubben
Post by gubben »
Thanks Ian, the king pin problem is history. A firm hit with a BIG hammer did the job!
/Thomas
Congrats!
Congrats!
