Felt seals on front stub axles.
garagiste
Post by garagiste »
How many felt seals should there be on the front sub axles.
The inboard ones fine, but should there be outer ones?
Some diagrams show them others not.
Re: Felt seals on front stub axles.
There's one behind the bearing, and on the later SV cars with Magna wheels, there was a small one inset into a brass cap under the stub axle nut that covered the bearing, and this brass cap had =an integral greaser. On the earlier cars, there was a steel disk with holes in it under the stub axle nut and no felt washer, so grease could escape into the small-centre wheel.
garagiste
Post by garagiste »
Ian, Thanks.
