Ignition and springs
Posted: Sun Jan 01, 2012 6:15 pm
The ignition system looks a little tired, indeed the HT leads are badly cracked and the distributor caps jumps off every now and then. The advance and retard has been 'set' somehow and does not rotate. 1st job is to replace the HT leads and sparkplugs. The latter are marked 'Autolite B7'. Can anyone recommend a more modern alternative and where to get them from, together with HT leads.
Does anyone have the spec for the springs on the from brakes? On one side there is a single spring and on the other there are three.
John.
John.
