Trying to recommission the Minor after 18 months of SORN due to sticking valves.
When reassembled on the car the dynamo doesn't charge, but was working when last run and it works fine on a test bench.
In my ownership the car has never charged on half charge and I know there was no resistor wire in place on that part of the circuit.
The fact that it works on a test bench seem to point to a switch or earthing problem at the dashboard which we have failed to track down.
Has anyone else encountered anything similar which might help me?
Charging
This from the MMM Forum which looks worth following up:
Go to http://www.woodauto.com. The contact there is Mark. A brand new MMM armature and field coils for 6 volts is £80 or if you want to convert to 12 volts the kit is £140. A brand new, no exchange dynamo is £305. A reconditioned armature with new commutator is £68 and £78 with a new shaft. Sounds worth following up.
