Rear Engine Mounts
crusher
Rear Engine Mounts
Post by crusher »
Can someone tell me the correct size of the rubber rear engine mounts on a '29 Minor or whether the one's listed below are correct.
I have 4 rubber mounts which appear to be original Morris Minor "new old stock", the rubber is in good condition but seems quite hard.
They measure 1 19/64" H x 2 1/4" W with a 3/4" wide metal band around them.
The hole is the correct diameter for the tube in the mount.
Thanks, Allan Coates (in Australia)
Tony Gamble
Minor Engine Mountings
Post by Tony Gamble »
According to Harry Edwards catalogue [ Yesterday's Components Ltd. ] the engine mountings for the Minor are rubber with no metal bands around.
Front Mountings are 1 3/8 " dia. and 5/8 " thick
Rear Mountings are 1 3/4 " dia. and 1 " thick.
I think that the mountings with bands round are M8 !
Hope this helps. The alignment of the prop shaft can be awkward if you get the mounting wrong , as I'm sure you may have found.
Good luck.
Tony Gamble.
I get my rear engine mounts fromm Mike Dowley at Sports & Vintage, and his all have steel bands around them - presumably to stop the rubber spreading under the weight of the engine.
