Uprated camshafts for SV Minors
ayf395
Re: Uprated camshafts for SV Minors
Post by ayf395 »
Oops, ignore the bit about the valve clearance, it is getting late.
A quick measure of the valve lift on the readily available camshaft gives a lift of around 6-7mm with a head clearance of 11mm even with a skimmed head.
4 branch manifold and twin carb on a minor apparently gives 75 mph which would give a closer match to your Norton :D
