I have the following available for sale.
parts need to be collected from near Launceston in Cornwall.
A 1934 family 8 pressed steel floor pan (provides foot area for rear seat and cover propshaft)
A 1934 family 8 inner scuttle in rough condition (the bit you see attached to the firewall when you open the bonnet)
The steel box from under the passenger seat in very rough condition
All of the above £20.
I also have two mystery wheels. They have the 1931 pattern centres but made in one pressing. There is an additional pressed baffle between each of the stud holes and 16 inch rims. The pressing of the baffles (presumably for strength) has slightly distorted the back. They came off a minor axle that had been used for a trailer and would suit this purpose again.
£5.
I also have loads of 1930s austin ten axles and various 1930's magna / easy clean wheels (not minor) - all very cheap to collector
various family 8 bits
