Tyres
Tyres
Hi All, It is possible I shall be wanting some new tyres for my 32 Minor. I have looked around and know what is available and at what cost. What I would like to know is what if any seem to be the best for the Minor. Thanks Mike.
Re: Tyres
http://www.vintagetyres.com/display.asp ... &m=6&dc=17
or..
http://www.vintagetyres.com/display.asp ... 9&m=4&dc=8
but my preference is the 450.....
or..
Re: Tyres
Thanks for all your replies I have looked at all these and would have gone for Blockley but have also heard that they wear quickly. Mike.
Re: Tyres
Excelsior tyres are first class and reasonable prices. I have them on the 10/4. Got mine from North Hants Tyres in Fleet.
Paul.
Paul.
Re: Tyres
do you mean these........???????
http://www.northhantstyres.com/main%20t ... 019exc.htm
be aware, that they're more like a 350 than a 400........ and as such, can look a bit skimpy...! just my opinion............
Re: Tyres
The 3 stud tyres that I am using are called Classico. When I bought them I think they were the only 3 stud type available, but they seem to be wearing well. I have also seen an Excelsior tyre that is 3 stud. I am sure I have read that Blockleys are available in different compounds.
Sticky tyres are not recommended for cars like ours - instead of the dreaded side-slip they tend to topple over.
Re: Tyres
The Excelsior which looks like the Blockley is also a racing tyre.Mike.
Re: Tyres
What is wrong with Avon sidecar tyres 350 x 19 ? I have 5 on my 1932 Minor two seater and they have worn well over the six years I have driven her. I was at a 80th Birthday party last week - 1929 Austin 7, and about a dozen Austins turned up all on Avons. Clive Loveless had two brand new tyres and tubes with him so they must still be made. I have done well over 10,000 miles on mine - what mileage do you do? , or expect to do? Highlander.
Re: Tyres
I have always used either Avon triple-duty 350x19 sidecar tyres or the more expensive Dunlop 400x19s. These newer tyres are nice because they reproduce the original triple-stud tread pattern. But other than that, the Dunlop or Avons are fine.
Re: Tyres
You can also get a 350 that looks like a classico from longstons there not as soft as a blockly. I have used them on an Austin and am very satisfied. i also use Avon side car tires which are equally as good but don’t look quite as nice. If you want cheep blockleys where the cheapest at one point.
Hope this helps and doesn’t add more confusion
David
David
