Red fibre
Red fibre
Does anyone know where I can buy red fibre in sheet form? I need 1/16" and 1/8"
Thanks!
garagiste
Re: Red fibre
Post by garagiste »
Have you tried Novus Sealing Ltd?
Re: Red fibre
I took a look at their product catalogue, but they don't seem to have anything that looks like red fibre. I actually need it for the small round 'biscuits' that separate the streamine flying wires on the Tiger Moth where they cross - so they should at least look like the original red fibre material. The 16th inch I need is for a similar application inside the wings where drag wires cross, so the appearance in there doesn't matter.
Re: Red fibre
Do you mean the stuff that fibre washers are made of ?
Re: Red fibre
Yes!
peterb
Re: Red fibre
Post by peterb »
Vintage Car Parts sells red fibre sheets 300x300mm.
1/32" (0.8mm)
3/64" (1.2mm)
1/16" (1.6mm)
Re: Red fibre
Thanks Peter - I''ll contact them to see if they can point me to the source of some 1/8" as well.
Mike Stubbings
Re: Red fibre
Post by Mike Stubbings »
Could you not stick 2 layers together with some suitable glue. Mike
peterb
Re: Red fibre
Post by peterb »
R H Nuttall supply vulcanised red fibre. Max size 3mm. May do small quantity.
http://www.rhnuttall.co.uk
