Master chassis register
Area for anyone experiencing problems with the website or the forum.
ian judd
Post by ian judd »
I have been trying to look at this and it seems to download alright- but when it opens it only has 37 entries, stopping at 1922. Can you tell me what I am doing wrong?
DF9053
Re: Master chassis register
Post by DF9053 »
I'll leap in here as Ian G may not be checking this too often at the moment.
I have just checked the chassis list and it is working fine for me.
Across the bottom you should see a series of tabs, starting with Bullnose. This list is the one that opens when you load the file. This list only has 37 entries.
If you select another model from the tabs along to bottom, just click on the model name then you will switch to a different list on a different page in the spreadsheet some of these lists are much longer.
All models are there so keep hunting for the ones you are interested in, the M type one is after the ohc and sv Minors.
cheers
ian judd
Post by ian judd »
Thanks Jeremy, but I'm afraid it won't work, probably because I've got a Mac and it's having to translate it. Basically I don't get any tabs along the bottom.
Any ideas anyone?
