Text size
Posted: Sat Jan 27, 2018 9:00 pm
by garagiste
What has happened to my text in the post I put on "technical" a few minutes ago?
David. :( :(
Re: Text size
Posted: Sun Jan 28, 2018 2:36 pm
Hi David,
It looked OK from here, but the image was very large which might have been the problem. I re-sized it for you.
Is that OK now?
By the way, a good tip which I have not seen before. One thing I learned about gearboxes the hard way with my very first Minor back in the seventies was to never let the weight of the gearbox hang on the input shaft inserted into the tail bearing in the flywheel when removing the box. The shaft can seize in the bearing making it impossible to withdraw the box. Always take one of the top bolts off last, and support the weight of the box while undoing this last bolt.
Re: Text size
Posted: Sun Jan 28, 2018 5:37 pm
by garagiste
Thank you Ian, it now looks better.
David.
Re: Text size
Posted: Sun Jan 28, 2018 6:45 pm
My pleasure David.
If anyone else wants to post photos to the forum, if they send them to me, I can size them and then I upload them to a directory on the website so they stay visible in posts for all time.
